3/8" Hilti Kwik Bolt (KB-TZ)
Posted by Mykel Keamoover 4 years ago
I am trying to do a calc on a 3/8" Hilti Kwik Bolt (KB-TZ) but the smallest bolt size I can use in the calcs is a 1/2" bolt. Is it possible to use a 3/8" bolt?
Single anchor,3/8" Kwik Bolt
2 Replies
Posted by Ashley Couronover 4 years ago
Hi Mykel,
Hilti does have technical data on the 3/8” diameter KB-TZ. This information can be found here.
Regards,
Ashley
1 comment on this reply
Thanks Ashley! I was wondering if there was a way to select it in the anchor designer instead of doing the calc by hand. The smallest diameter I see in the program is 1/2" bolts
Hi Mykel,
Unfortunately, the KB-TZ is no longer available in PROFIS Engineering.
Regards,
Ashley
