18-8 Stainless Steel
Posted by Octavio Martin over 3 years ago
Is 18-8 stainless steel a valid substitution for 304SS threaded rods? Both seem to fall under ASTM F593 and have a similar chemical composition with similar mechanical properties. Some sources even equate them both. Just needed to verify.
stainless steel grade 304 anchors,Stainless Steel Theaded Rods
1 Reply
Posted by Ashley Couronover 3 years ago
Hi Octavio,
If you are installing one of Hilti's adhesive anchoring systems, the requirements for permissible threaded rods can be found in the ESR document. If the threaded rod meets the requirements laid out in Section 3.2.5 of the respective ESR document, then the threaded rod is able to be used with the adhesive.
Regards,
Ashley
standard threaded rod,adhesive anchor system,ESR number
